Just a question about how you like the action on your folder's.
I tend to tighten my blades fairly tight and have no fear that the blade will accidently open in my pocket. This is for my liner/frame lock knives. It may make it require a little more thumb to open it on one push, but I've done this for so long that I guess I have developed a strong thumb!
When I do openit there is no slamming the blade against the blade stop and no movement in the blade when locked up. I have seen my share of loose blades that wiggle all over, but purposely done that way so that they can open fast and "impress"
folks. Not for me.
On my locks I like the locking liner, or frame, to have a good degree of stifness to it. Not only does this help keep the blade locked up when open, it also helps to keep the blade inside the handle when closed. Just the way I like it to be! On most every liner/frame lock knife I have, I have put more stiffness into the lock by putting a little more bend into it. Now I don't go wild and bend it out to 90 degrees or anything
, but just a little bit. So far I have not had any premature movement to the right, as they all keep the lockup they had before I did them. The stiffer lock pretty much assures that the blade is not going to come unlocked until I make a conscious decision to close it. Of course I am aware that certain rotating movements of the handle, when the blade is immobile and not able to roll with the handle, can cause the lock to move off of the blade causing the blade to become unlocked. I've not yet experienced this.
Anyway, I figure I can't be the only one who likes such a setup and I wanted to hear from anybody else who like to set up their knives with a "tight blade and stiff lock".
