In addition to the break in, I can say that each of my several xm18's whether regular 3.5 or fattys have all come with the pivot too tight.
I also like to completely disassemble each new knife, clean everything carefully with windex taking care to wipe off the factory gunk (lubrication.)
Then re assemble it. Use a drop or 2 of Nano or Daiwa oil (most lubes work but I have found the Hinderers to like thin oils better than thicker greases like Reeve's flourinated grease. Nano or Daiwa oils work very well and that is all I use.)
Lube the pivot female part lightly on the outside, a thin circle's worth of oil on the inside of the lockside at the pivot, the washers, and both sides of the blade tang. Don't forget a tiny bit on the detent ball.
Now carefully put it all together the same way you took it apart. Adjust the pivot to your liking and center your blade if need be.
It is important to remember that "less is more" with the oil. Also, do not use oil or any kind of lube on the handle screws, standoffs or handle nuts.
I can tell you from experience that after doing this to each new XM I have bought, all problems were solved as far as smoothness, flipping proficiency and detent. Occasionally, lockbar pressure had to be increased or decreased, but not often enough to worry about.
If you have questions or get stuck, shoot me a PM. I'd be happy to help.
