Tightening pivot
OK, so this is an embarrassingly simple question...the pivot screw on my frn dragonfly won't tighten because the other side moves with it...the other side of the pivot is smooth so I can't create the friction needed to tighten it...is there a simple solution to this simple problem?
I know with almost all spydercos the pivot (or one side of the pivot) is shaped like a D that slides into a hole in the scales that are like a D, this way the pivot doesn't turn. If you're pivot is turing then you're scales or pivot screw is probably messed up.
Hmm...I remember this from taking apart my manix now that u mention it...but I can't take the pivot out to inspect for the same reason...
If you are careful enough you might be able to drill 2 small holes and use a security bit or cut a slit and use a flat screwdriver...?
