- Jun 27, 2013
Hello everyone,
TimberGhost Custom Knives here with some info and pics of our newest friction folder model. The TG CARNAGE. We are super excited about this model as we here at TimberGhost Custom Knives are avid bow hunters. I have wanted to get this model done for quite some time now and am blown away by the overall look, functionality, and innovative design. Here are the specs and some pics enjoy.
Knife Specs:
Main Skinning Blade: Big belly perfect for skinning!
Length: 3" (3 1/2"cutting edge) with sharpening notch 7” overall knife length
Thickness: 3/16"
Steel: This knife was made from D2 steel and hardened to 60 HRC
Grind: Full high "lean" Flat grind with a convex micro bevel
Finish: Two tone Acid Stone Wash (main skinning blade) and Fine Satin Finish (gutting blade)
Thumb Choil
Gear Jimping
Swedge
Accent hole
Gutting Blade: Designed specifically for opening the belly section and other tasks when field dressing big game.
The gutting blade is shaped at just the right curve to make opening the belly section of big game with no risk of puncturing the internal organs.
Length: 3 1/4"
Thickness: 3/16"
Grind: Full high flat grind with a convex micro bevel
Finish: Fine Satin Finish
Sharpening notch
Full length sleek swedge
Handle:
Length: 4”
Material: Ghost Jade G10 (reptilian pattern) with Hunters Orange G10 liners
1/4" Lanyard hole
Sheath: The sheath has great retention but still unsheathes with ease from a little push on the thumb ram.
(.080) Holstex Carbon Fiber sheath
1/4" Nickel Eyelets that are spaced to fit a large Tek-Lok
Two accent holes (one on each side of sheath) that reveal the forward most pivot screw
Drain hole
Thumb Ram
G10 is an epoxy based high pressure laminate that used glass mat (think fiber glass) for the fiber base. It's a durable material that not only looks and feels great but it will last for the life of the knife. The "Reptilian" pattern G10 scales provide excellent grip!
Features:
The TG CARNAGE has many features that make it a great knife. Innovative double bladed friction folding design, 3/16" D2 steel hardened to 60 HRC, reptilian pattern G10 scales, sharpening notch on both blades, perfect swedges, thumb choil, gear jimping, 1/4" lanyard hole, two tone acid stone wash/fine satin finish and a Holstex Carbon Fiber sheath.
I know there is a ton of hunters out there that will absolutly love the TG CARNAGE! Thanks for taking the time to review this thread. Let me know what you guys think and I'll catch you all on the next one.
Knife Specs:
Thickness: 3/16"
Thumb Choil
Gear Jimping
Swedge
Accent hole
Length: 3 1/4"
Thickness: 3/16"
Sharpening notch
Handle:
Length: 4”
1/4" Lanyard hole
Drain hole
Thumb Ram
Features:
