Timberline 18-Delta Series
Timberline Tactical 18-Delta Series
Model 7866
General Info:
After hearing a little bit of buzz in the air about this knife, I decided I needed to try out the new stuff. I think the Greg Lightfoot has some really interesting knives out there and thus far his partnerships with various manufacturers for production knives have been quite successful. I’ve included two common ‘production’ knives (CRKT M1 Lightfoot and Buck/Strider SBMF) which copy the designs of more famous makers in the photos for size comparisons.
The 3 ¾” blade is 440C and very sharp out of the box. There are plenty of super steels out there that might also be suitable but this knife is marketed to be a no-frills, tough, hard-working knife to take to the “field.” As such, 440C is still a viable choice. The Ti-Ni coating is nice and uniform. This particular drop-point uses Greg Lightfoot’s asymmetric profile as can be seen when comparing the right and left sides of the blade. The actual grind is in fact a hollow grind. If I was picky, I could say that there are very slight tool marks on the blade but one would need to use the macro-setting on the camera is capture that.
The handle uses titanium liners and G10 grips. Both are extremely well machined. No burrs were found on the liners nor G10 and the overall frame is sturdy in the hand. The knife is well balanced right at the index finger groove and I love the feel of the remaining fingers fitting along with the pinky finger groove.
Fit and Finish
The blade locks open very positively and there is a satisfying snap engagement of the liner-lock. Also, the thumb-stud indexes very well, which feels natural to thumb-open so that no overly-deliberate action is needed. (The same cannot be said of the CRKT M1 Lightfoot pictured where the thumb-stud is really the blade stop pin and more of a back-up thumb-stud because the flipper is for primary opening).
There is absolutely no vertical play on the blade. However, when holding the liner down, some slight play can be noticed LATERALLY. Generally, this is indeed more common on knives where the blade stop-pin rest at the back of the blade unlike the thumb-stud/forward pins like those found on the Strider-Buck and CRKT.
Additionally, I believe this may in part be due to the washers used by Timberline. Unlike many knives (such as the cheap pig-sticker Buck-Strider SBMF) which use single solid brass washers, it appears that the Timberline Tactical 18-Deltas use a number of brass shim washers. This is probably for production assembly ease to allow for larger tolerances but it also allows for more likelihood of movement if the assembler did not stack the maximum number of washers on. I have emailed Timberline to find out what are their acceptable tolerances and I am awaiting their response. If I go about dissembling the knife, I may have try to add some shim stock or go to Home Depot and get the suitable solid washers to fit in instead. ….if I’m able to dissemble the knife…
You will also probably ask why I haven’t just tried tightening the pivot screw. The blade pivot screw has a nice texture profiled to emulate the G10 somewhat. The slot for the flat head is unusually narrow and off-hand, I can’t find a flat-head that even manages to fit in the slot. I could file down a screw-driver….but if this knife is supposed to be a go-to knife, I’d be hard-pressed if I had to do basic service(er..tightening) simply because I can’t find anything to jam in there. I’m not sure if Timberline intended it to be end-user serviceable. This is something also questioned in my email to Timberline along with the inquiry regarding the lateral blade slop. I may simply call their Customer Service for a quicker response.
Another issue I would like to stress is the pocket clip design. The clip seems somewhat of an after-thought. The clip is much too narrow and close to the grip. While this would in theory make the clip less of a hindrance while gripping the knife, the clip offers too narrow of a space to fit your pants, particularly going over the pocket seam. Additionally, Timberline has used round head Torx screws which act as an additional barrier to overcome on your pants. Lastly, the clip itself is skeletonized and while some knives’ grips make tear your jeans/pants, over time with the 18-Delta, it’ll actually be the clip doing it rather than the G10.
Gripping the handle with the clip can also be a source of gripes. The ramp for engaging the clip on your pants is a tad high. In certain grips, this ramp will rub in between your index and middle finger knuckle or the web of the fingers. Possibly something to overcome but I like to dictate how I grip my knife not the other way around.
For whatever it’s worth, the clip’s ramp can probably be bent down some to better accommodate. However, it’s really too narrow for even your dress/parade pants for regular use. I suppose you may stick it on a MOLLE slot.
Overall, I’m impressed by the Titanium/G10 handle working/finish and blade profile. The clip is a lazy, ill-thought out design. The lateral movement somewhat discredits it as the sharpened chisel, go-to knife. So I'll give the benefit of the doubt and I’ll await Timberline’s response to pass final judgment with regards to that. If anyone has an issue of Tactical Knives July 2008, I’d love to hear what they said about this knife. I haven’t had a chance to get a copy.
Good review, I think you'll find that those washers are bronze not brass though.
Touche..
My bad. Bronze shims they appear to be. I'm going to dig around finding a thin flat-head screwdriver and give it a go.
Have spoken to Gatco customer service and they said to simply send it to them otherwise.
For anyone thinking about the 18-Delta, since noticing the lateral play, I have sent the knife back to Timberline for replacement.
They sent me back the 7866 which was super tight at the pivot with proper use of the bronze washers. There is no play what-so-ever on it.
One criticism regarding this may be that Timberline seriously could have saved the trouble of all this by using a pivot pin that the end-user can actually adjust themselves. I have no idea how it is locked down but the flat head slot isn't just a screw... Timberline then could have just sent replacement washers to the client.
The other criticism regarding the clip in the original overview remains. The clip is simply too narrow to fit with ease over your pant pockets for EDC nor does it fit with ease on MOLLE gear.
I may decide to make my own clip or attempt to reshape the original ...
This is the first time I've read this review, and it is a very thorough one to boot, GOOD JOB.:thumbup: I have liked the looks of this knife since first seeing it. At first glance, and even at second glance, it looks a lot like G. Lightfoots Catch Dog, which is a very good looking design. At first I was held back by the price being so low, and it having titanium and G-10 in it, that I was afraid of sloppy workmanship, then found out it was manufactured in China, and that sorta put it on the back burner for me. But after reading this review, I'm considering going ahead and purchasing one. :D
What you noticed is indeed correct. The 18-Delta is in fact 'intended' to be a production version of the Catch Dog(as you may compare in photos).
With regards to the workmanship, I have to say that it is pretty high up there. The pivot slop was probably just an exception and more than likely most will come locking like the one they sent back...ie tight and secure. If it isn't to your standard, Timberline's service has been quick and I'm sure they'll make it right as they have been able to do for me.
Everything else is very nicely done. As mentioned before, all very nicely uniformly machined titanium and G10. No burrs on the handle, blade finish excellent.
While I'll gladly support products made in North America, I have no qualms about the quality of some products coming out of China. Don't expect the 'IN' steel(eg S30V) of the moment flying out of Chinese factories, but for tried and proven basics like 440C, the Chinese has been able mass produce serviceable, quality items.
Now the knife isn't cheap(nor is it expensive), in fact it's about Spyderco Police money....but whereas the Spyderco Police is a nice slicer, the 18-Delta is a stout, sharp knife with a strong tip and geared for 'heavier' work.
Image from Lightfoot: Catch Dog
