JK Knives
Moderator
- Mar 6, 2001
I`m going to auction these two off. Bidding will end on October 31st, at 12 noon.
This is a 5" closed, 8 7/8" open Friction Folder with 1/8" thick titanium handles. The blade is made from 5/32" thick O1 steel, and features a saber grind, with the flats left in a heat treat finish. It`s held together with 8/32 allen bolts for the pivot, and 6/32 allen bolts holding it together. There are .016 thick bronze washers on either side of the blade. It also features a screw locking function, turning into basically a fixed blade, if you decide you need a bit more security while working with the knife. Bidding will start at $100
Here it is in the closed position. The screw nearest the rear of the handle is a thumbscrew, which you can remove and place in the hole through the handle and blade tang to convert to the fixed position.
Top view.
Here it is opened up. You can see the thumbscrew in the blade locking hole through the tang.
The first cord wrapped collaboration knife from Connie and myself.
8 1/4" oal
4" blade
1/8" thick O1 steel
Heat finish on the flats
Scandivex edge
This one is green camo wrapped
No sheath
Bidding will start at $50
Top view.
8 1/4" oal
4" blade
1/8" thick O1 steel
Scandivex edge
No sheath
