Time for new sharpening equipment
I've been getting along pretty well with only the Norton 220/1000 waterstone and haven't wanted to shell out $80 for their 4000/8000, but it wouldn't be such a big deal now... However, before I go ahead and buy it, I'm just wondering if maybe I should check something else out and maybe even look into moving away from the water-stones.
Diamonds are looking more and more appealing, I mostly just don't like flattening the waterstones. In any case, now would be the time for me to invest in some more equipment so I want to get some good stuff since I'll probably be pinching pennies again for a while fairly soon.
I bought a DMT 6" Diasharp Kit for $80(not including shipping). Works very well, did a nice job on a cleaver shaped Chef's Knife(too thin to be a true cleaver).
You can also try the Work Sharp if you feel comfortable with using power tools to sharpen your knife edges. With the P400 and 1800 belts from the maker's website, that should cover all of your sharpening needs, particularly if you have recurve blades.
If you buy a spare 6000 belt or two and some Mother's Mag and Aluminum Polish, you can wear out one of the 6000 belts by rubbing P60 grit sandpaper against it, put on the Mag Polish, and use that as a power strop. I find the finish is easily on a sub-micron level(cuts through hair instead of just splitting it and tree-tops leg hairs).
I'd go with ceramic and water stones for anything higher than 1000/1500 grit. Diamond are great for anything less than that. If your still thinking about the Norton 4000/8000 combo hone I'll give you a suggestion better than $80 email me at dbtoe@hotmail.com
kenny, for around $100. you can get set up with a set of the paper wheels which will last you many years. i sent you an email also :D
