- May 21, 2003
Here's what some of the promotional material says:
Q. What is the composition of the metal alloy used in Chef'sChoice® cutlery?
A. The specific formula of the steel alloy used in Chef'sChoice® cutlery is proprietary. However, it contains much higher levels of carbon and stainless alloys than the popular European or domestic brands. It is important to understand that the alloy itself is only part of the reason for the outstanding performance of Chef'sChoice® knives. EdgeCraft research scientists have also developed special aerospace metallurgical processing and forging technologies that, with the alloy's unique composition, produce a knife of incredible strength, toughness, and durability.
EdgeCraft produces totally unique cutlery by forging with a steel which has exceptionally high tensile strength. This proprietary steel gains its strength and uniqueness because it contains twice the carbon (over 1%) and on the order of 10 times (over 3%) the molybdenum used in Soligen, Theirs, and U.S. household cutlery. The high molybdenum content adds flexibility and toughness. Called Trizor® steel, its chromium content is in the conventional range (13-14%) for quality stainless steels, yet its ability to provide stainless properties is enhanced further by its uncommonly high molybdenum content. Borrowing novel technology from the aerospace sector, and adding radically new processing procedures, has made it possible for us to forge and condition this new ultra-strength steel to achieve major gains in strength and toughness for the stainless blade.
Because Trizor® steel is stronger and tougher, it will take a better edge and retain that edge up to ten times longer than knives of conventional steel such as those listed above. The tensile strength of steel is directly related to the Rockwell hardness of the steel. Trizor® steel knives have a hardness of Rockwell 60 compared to 52-55 for conventional European knives.
Chrome-vanadium-molybdenum stainless steel is tempered and vacuum hardened to create an extremely rugged blade that takes a razor sharp edge and stays sharp longer.
1% carbon + 13% - 14% chromium + 3% molybdenum + vanadium.
We probably can't come up with the correct answer, but if the promotional materials are accurate (I Know--a HUGE if) then what do you think it is?
I looked for something with similar levels of carbon, chromium and molybdenem that also contained vanadium and used aerospace inspired vaccum processing. I only found one steel. I'd be surprised if Chef's Choice uses that steel in chef's knives, but at $80 for a 6" chef's knife I suppose they could afford to do so.
What do you think it is?
