Time to rebuild my EDC..
Been Carrying my military for three years now and it's time to replace some missing/damaged parts.
As you can see I need a new pocket clip, screws for clip (using endura parts knife screws now) and and all new scale screws.
I would like to upgrade if possible to a bigger stronger torx head screw (the ones that are left are stripped)
Could someone please point me in the right direction for buying these parts? I know I can get the clip on EBay
Start here, http://www.bladeforums.com/forums/showthread.php/1125809-Spyderco-Military-standoffs It is a thread mainly about the standoffs, but screws are discussed, and websites are given. As far as clips go, STR here on the forums can supply a deep carry clip if you wish to change/upgrade. I did something a little different for my clip, http://www.bladeforums.com/forums/showthread.php/1124348-CRUWEAR-Military-Converted-to-Tip-Up I also would not write that clip off, you may be able to bend it back into shape. A little heat and some motivation could have you back in business.
PM me your address and I'll send you the upgraded screws. I also made a titanium deep-carry clip for my Military but I'm not using it, I can send you that one too.
The clip should be easy to bend back and Spyderco will send you free screws so you should be fine (give them a call, Charlynn is great). Otherwise the above offer is great:thumbup:
Just the way they should look after a few years use :thumbup:
How has the lock worn in after that kind of use ? Have any blade play?
Cheers
Cheers
Lockup is incredible.. Zero side to side and you really have to grip it and jerk the blade to get the slightest up/down.
Every time I'm around someone and knives come up I Pull out the military and tell them its been used and abused for 3 years and have them check blade play.
I'm probably spydercos top military salesman:D
