Hey Joe....
Ok,,basically this is how it works...
There is 2 parts to the fire piston..
The Barrel is a solid chunk of Acrylic that has been Exactly machined to certain tolerences.
The Piston which has a couple of features..
Firstly the the piston has a very close fit..The air seal is created by two O-rings that are machined into the piston..
At the end center of the piston is a little hole..This is where the Char cloth is placed...
The piston is placed into the tube and then it is stuck with the hand hard against something solid..
What you have in effect is a simple dielsel engine...
As the piston travels down the tube it compresses the air that is trapped in the tube. The compressed air creates something like 800-1200 degress of heat Extremely fast..The heat is what ignites the charcloth at the end of the piston..
The piston is then quickly extracted,,and the burning ember is placed onto another piece of char,,placed into a tinder bundle and blown into a flame...
Any type of vegtable oil can be used as a lubricant.I've even used siliva in a pinch..
It works Exceptionally well and is fun to watch..
Very little to go wrong.
The clear acrylic tube allows the user and spectators watching to see the Flash of the Tinder..Hence the name Tinder Flash..
Pretty cool,,fun stuff...
Hope that helps Joe..
ttyle
Eric...
