- Dec 26, 2006
Well, just sitting in front of the tee vee tonight, cruising BFC, and decided to mess with one of my new 110V Shallots. I'm now very glad I did!
First thing was to dig out a 1840CKT donor for the handles. I dunno, but to me the CKT has a much better grip. Feels less slick. So tore both down, and before swapping blades I took the time to clean and lube everything. Interesting to note: both Shallots had SPS. Folded dish towel on the coffee table trick and no problems. I put both back together and set the pivots exactly where I wanted them. Both knives interchanged blades perfectly, and the lock-up is fine on both.
Next came the Sharpie. The 110V from Kershaw was already closer to 30 than 40, so no need to head to the garage. About an hour of working the edge, and wow! Set perfectly at 30, this steel cuts like a razor. I kept fiddling with it, and the more I worked the very fine sharpmaker rods, the better the edge got. Finally satisfied, I very lightly put the edge on some green compound. I'm slicing cellophane now. Stropped it a few times on non-loaded rough leather, and its perfect! Splits hair! Tied a gutted 550 paracord lanyard to it and done! 3 hours to perfection. :thumbup:
With this edge as sharp as it is, I plan on carrying it for a week or two just to see how it holds. If it keeps the edge, it's going thinner. This steel will be a monster at 22 degrees!
If you have a 110V Shallot, use it! If you don't, you'd best get one while you can.
Thanks to Thomas and Kershaw for bringing this great steel to the market! :thumbup:
