- Jun 11, 2006
I was threding a liner for a slip joint foldar when the piece of $hit broke of. i could not get to to buge with the plyers. i then got real pissed because i was messing up my nice liners which are 1/8" thick. i finley decided that i needed to make another one after allmost throwing it acros the room with a string of profanity when my wife told be to put it down and go eat some icecream. i sat there eating when it hit me, the tap was hardened steel so why not remove the heat treat and dril out. i jumped up and ran to the kictchen and turned on the stove, i then put my liner on the burner and let it come up to temp which i thing is around 1200 because i was getting oxide flakes. then i turned off the stove after letting it soak at the temp for around 5 min. i then got out the handy dremil tool and chucked up a tungstion carbide bur. i went to town on the broken tap and in 2 min i had it out and i was jumping with joy. i just thought i would let every one know how i fixed this problem so others might not get as mad as i did. also if you have any other solutions let me know.
