Knives like the Mili and Para are biased to open towards the heavier hump of the blade where the SpyderHole is. As such, configuring it that way from the beggingin meant blades opening up in the pocket - not so nice. With tip down, you don't have that problem. Now, I think the new Para2 has some design features that help to hold the blade closed - however I have never had a problem transitioning from tip up or tip down.
One thing I wish Spyderco would do is have their knives come tip up carry set up from the factory.I believe most users prefer it that way so why make them switch it around?Maybe I'm wrong,what's you're thought?
With tip up carry, the spine of the blade is pressed against the seam of your pocket (Unless you carry your knife clipped in strange positions) so it can't open accidently. Tip down, the blade is free to swing open in your pocket.
I say everyone should try both and see which they prefer. There are benefits to both methods of carry.
There is absolutely no reason at all why a decent folder shouldn't have four-point carry other than sheer laziness on the part of the designer and/or maker.
I think that reducing the weight by installing less of a liner is a reason to not offer a tip down option. Also, by only allowing one carry option it eliminates extra holes.There is absolutely no reason at all why a decent folder shouldn't have four-point carry other than sheer laziness on the part of the designer and/or maker.
I like tip up because you are already holding the knife in your hand the way its "supposed" to be.
