Old CW4
BANNED
- Sep 8, 2006
I know a lot of you folks work on your own guns so here's a gunsmith's safety tip:
When you've done an extensive or complete dissassembly of ANY semi auto firearm, have it back together, and are about to test fire it, load ONLY two rounds in the mag, and repeat this two or three times to ensure the firearm functions correctly!
This is just in case you've inadvertently turned your semi into a full auto. I've seen semis on the range go full auto and it can be really dangerous as the startled shooter is suddenly spraying bullets at a high rate of fire. I've seen this happen twice with 1911 45s, once with a 30 Carbine, a MI Garand, and a few times with various other makes and models, in one case, even a tube fed 22 semi auto rifle. BTW, when that shooter's Garand let go I was behind him and still remember the weird 'BARRANG' sound. I also retain a vivid mental image of all eight brass and the clip in the air at the same time. It knocked the guy down and broke his shoulder.....
When a customer brings in a semi with a problem I always test fire at least twice with only two rounds in the mag. After repairs I do it again. A rapid full auto 'burst' from only two rounds you can control but 8 to 15 or more rounds at full auto is another matter entirely especially with a pistol.
On, just in case someone asks how do you put only two rounds in a Garand's eight round clip? Just put in six empty brass with the live rounds the last two at the top.
