Hi gang,
Searched, but didn't quite see what I was looking for.
I have a DMT Magna-Guide, and DiaFolds from XCoarse all the way down to XXF (though, my XCoarse is a single-sided one, and thus when used on the Magna-Guide, it has a slightly different angle from the double-sided DiaFolds - wish they had mentioned that in the ad copy! so now I need to buy a double-sided XC, I guess an XC-C one).
I reprofiled and sharpened a knife on it, and it worked great, but had these questions:
1. The slot the metal bar goes into, it matters which side of the slot you push the bar against, right? Since that will slightly alter the angle at which the diamond surface hits the edge? So, do you guys just pick a side to push against, and stay consistently there?
2. The angle changes depending on where the knife is clamped - toward tip, toward ricasso/bolster, deep on spine, shallow on spine... So, how do you go back to the same angle when you go back and re-sharpen a knife you've already given a once-over on the Magna-Guide before?
3. Any other tips on how to best and consistently use the MG?
Thanks!!
ps. I can freehand ok, but I do like the consistent edge angle that the MG can give, hence the thread.
Thanks!!
