I must be dead stupid, but I got the G10 side off, all torx off, and then attempted to loosen the steel side. The standoffs rotated around, but loosening them didn't cause the two sides to separate once the G10 was off. . I give the two sides a wee pull, but didn't want to apply TOO much force as I was concerned about warping one or the other. What on earth is holding them together? There is a retaining pin behind the blade but that's not budging either. Tight tolerances? The pivot screw LOOKS like it's got a lip that is holding it on to the G10 side, another reason I didn't want to force it.
As an aside I was able to fill the G10 side torsion bar 'well' with Finish Line Fluoro Lube and give the other side a good squirt through the crack. Even with the blade tension torx REMOVED this knife is NOT AN EASY FLIP. I have yet to complete one flip without some wrist flick. WITH wrist flick, however, it's awesome and makes a nice CHUNK. That's de-assisted. Don't even get my started on assisted.... All my fingers reasonable strength to overcome the detent setting. I don't think the torsion bar is coming back... nice knife, however, for $125 and sharp as H-E-C-K.
One more thing I have noticed. I CAN use the thumb stud to deploy -but when I'm doing it, i'm fighting myself, as my hand rests on the frame lock OR the pocket clip (which rests on the frame lock) causing extra tension on the ball retainer. Took me a while to figure out why the harder I gripped and pushed the less success I had deploying with thumb studs.
