Any tips on sharpening the composite blade Leek? I am encountering some difficulty.
I can get the edge sharp enough to make smooth effortless cuts through paper, slice through plastic blister packs with ease, and even shave arm hairs. When I take that same edge to thicker cardboard (even just single ply stuff), nylon cable ties, or packing straps, it takes quite a bit of effort to cut through. The factory edge handled all those with ease, so I must be doing something wrong.
Does the CPM-D2 need to be sharpened differently from other steels? I haven't had any issues sharpening other knives (mostly AUS 8, 8Cr13MoV, and a couple of VG-10 and 1095). I'm using a "fine" grit Arkansas stone for the sharpening and a leather strop infused with green compound to finish. Searching around online, I have found some non-specific comments about tool steels being different or more difficult to sharpen, but no real details beyond that.
The blade was still reasonably sharp before I started my re-sharpening attempt. I just noticed it was starting to take a bit more effort to do some cutting (specifically cardboard, packing straps, and cable ties), so I figure I'd touch up the edge. I think now, I might have actually made it more difficult to cut those materials. I use paper cutting as sort of a baseline for before and after tests when I sharpen, and that did seem to indicate some edge improvement from my efforts.
Any advice would be much appreciated.
