Sorry my bad, it says "made in China" on the knife. That`s what i meant to say that is is the cheaper edition with an "inferior" steel alloy. Does this mean it is stainless steel of some sort and not the AUS8 alloy? I really like the design of the ODA that`s why i have it. I`ve looked around on ebay for an example with the superior steel alloy but so far no luck. The metal on my knife is not black but "polished steel" i don`t like the black coloured Carbon V ones. My edge is sharp but not razor sharp. So using 1000 grit on this type of steel will suffice plenty? No need to think any longer about 3000 grit and so on?
1000 is a decent one to finish with so if the edge is already sharp, you may be okay. If the edge is thick, then it won't work. Given the intent of that knife, it may just be a thicker edge intended for rougher use, not shaving and kitchen work.
If the steel is soft, then you can get more basic stones and it will work well for you. No need for diamonds and such though the diamond stones are a nice investment if you're looking at harder steels down the road, like S30v and so on.
The biggest problem, in my opinion, trying to use the fine stone you have is it will take so long to get to a fresh edge that you'll either give up before you get there, not know you've gotten there (harder to raise a noticeable bur), or the stone will clog up so much that you just won't make it there.
For a reference point, a DMT fine stone is considered a 730 grit stone and that's a common finishing stone for people putting a working edge on a knife for the harder, high carbide steels. Course is about 390 grit. I used a micro to grit calculator to get the grit numbers as DMT has micron and mesh numbers on their website. I find the DMT course to be rather slow for repairs and the extra course is much nicer to use, which is about 290 grit.
One of the sharpeners I like the most is a buck edgetek ultra steel sharpening rod as the movements are very similar to using a kitchen steel and it has 3 grits on it. It's not great for repairs but It's not too hard to get shaving sharp with it if the edge just needs sharpened. It won't get you all the way back to the start of the edge as the rod is curved so you'll still want to get to a stone every now and then but that's what I use for most touch ups and it works well with recurves, harkbills, and kuhkris as well. And the price is very reasonable. I can't find who makes the rod for buck as it just a rebrand of a common diamond sharpening rod that can also be found on various websites.
