Erin Burke
KnifeMaker...ish
- May 19, 2003
Hi guys. I've been playing around with this knifemaking thing for awhile now... and during that time I've build a number of hidden tang knifes. My method for drilling and fitting handle material for a hidden tang works, but it is nowhere as clean and easy as I'd like it to be. My method consists of clamping the handle material in a cross-slide vise on my press and drilling a bunch of holes (adjusting the angle of drill to accommodate for the profile taper of the tang). I then connect the holes by pecking away with the drill press as I dial the cross-slide vise back and forth.
I find that this can cause a bit of deflection along the length of a long drill bit... which worries me when I can't see exactly what's going on in that hole. I did build a makeshift broach, but find that it's not really good for much. So the question for you experienced hidden-tang makers is:
What is your method? How do you ensure that the holes go straight where you want them? How do you remove the webbing from between the holes?... (I think I remember Nick posting something about a zip bit in the past). How much do you use broaches? Where did you get them? Are there tricks to building a GOOD broach? When fitting your handles, how do you check to determine where the binding is occurring and where to remove material?
Thanks in advance.
Erin
Thanks in advance.
Erin
