Then don't use an Emerson!! Try THIS instead!
I was concerned by all that talk about the liner locks on Emersons failing, yet I liked his Wave design for the deployment speed that it allows. Unfortunately, Emerson doesn't offer any knives utilising the locks which are, today, being touted as one of the strongest and safest: The Arc/Axis style of locks.
So in a moment of pure madness, I created the SOG Waved Vision. I used a bit of kydex that I had lying around to mould the initial shape. I was aiming for a small triangular tab of plastic sticking out from the area around the thumbstuds. The plastic would be held in position by the thumbstuds and the spine of the blade (thumb ramp portion). By not gluing it on to the knife, I allowed myself the option of removing it if it didn't quite work out, or replacing it if it broke.
The hook of the wave was shaped using my Dremel and holes were drilled to fit the thumbstuds (5mm dia.). I thought that would be strong enough, but after some initial testing, decided to stiffen it.
Fortunately, I had some woven glass fibre mats lying around too.
Didn't have the styrene that is typically used with glass fibre, so I used 24hour Selley's epoxy. Laid 5 layers of fibre and epoxy, then pulled the mess tight around the kydex. Didn't do it quite right as you can see. The fibreglass didn't quite conform to the kydex shape and I ended up with a squarish tab rather than the triangle I started out with.
When it hardened, the tab was extremely stiff. More shaping with the dremel to remove the excess fibreglass and re-drill the holes to accomodate the thumbstuds, then a final layer of epoxy to seal the lot up and give it a nice smooth finish. Then the tab was assembled on to the knife and the thumbstuds screwed back in to place.
Initial tests show that it works quite well, though it looks very ugly. It might actually be better for the knife to be opened this way as the blade is pulled open via both sides of the thumbstud, thus eliminating any lateral torque on the pivots.
BTW, the screw thread on the thumbstud needs to be heated before it can be disassembled.
