As I understand it, titanium is not stronger than steel universally. It is stronger than steel by weight. And so is balsa wood.
So two idealized wrecking bars of the same weight of steel and Ti respectively, the Ti will probably be stronger, but will also be bigger in size.
Two wrecking bars of the physical dimensions, one steel and one titanium, the steel will be stronger, but heavier.
If you want to compare two wrecking bars of equal strength, you'll have two otherwise dissimilar bars. The TI would be thicker, and perhaps longer. I am not sure which would weigh less in this instance, though I am guessing titanium.
Phil
