No.My 710 has a blade to back spacer contact issue. I'd like to install some titanium stand offs. Must the knife be completely disassembled to do this?
No.
It is definitely possible to remove the factory back spacer without disassembling the entire knife.
Losen the pivot screw a lot.
Almost all the way, but do not remove the screw.
Remove the two screws that are passing through the backspacer. At this point, the only thing that should be holding the backspacer in place are 2 plastic posts (1 in each liner) near the top of the backspacer (the end closest to the pivot). Grab the lanyard hole end of the backspacer and swing it out the back side of the knife.
Gently spread the liners at the very end of the knife near the lanyard hole.
At the same time grasp the exposed portion of backspacer and gently pull and twist.
The back spacer will come right out.
Do you have threaded standoffs or pass through barrel spacers?
