I recently bought a plate of titanium for some experimentation. My intention is to explore the utility/ practicality/desirability of titanium for a folder frame/ scales. Obviously, many others have already done this work and proclaimed titanium to be the ideal material for a folder handle.
My first impression upon removing this precious ($1 per square inch inch @ .125) sheet of metal from the package was that it wasnt very light. In fact, I wondered if a mistake had been made and stainless steel had been shipped instead of titanium. Nope, its titanium, the sheet ink markings say so.
I resharpened a #14 drill to 135 degrees, center punched , set the drill press on about 400 rpm, put a drop of coolant on the punch mark and drilled away. Result: no problems, a good hole. I tried several more with the same result.
I put the sheet in the vise and hand sawed off a chunk. ( I didnt want to risk a bimetal band saw blade) no problems, nothing worthy of note. I ground the titanium on a 60 belt. Very white sparks. So titanium appears to reasonably workable. I can fashion this stuff into a knife handle.
The question is WHY?
What does his material do that is superior to less expensive metals? Lighter? nope.
Stronger? all handle materials are sufficiently strong, no advantage. Beautiful? No really. The ground piece heat colored very nicely, but it was about as durable as the heat colors on a piece of steel, easily removed with a little rubbing. If it is just going to be bead blasted, it might as well be stainless or aluminum.
I guess that the answer is that titanium is exotic, expensive and exclusive. For a .125 handle slab, stainless is stronger, aluminum is lighter, and micarta is prettier. Aluminum can be hard anodized for an extremely durable and beautiful finish. Stainless can be machined, polished, and hardened for a virtually indestructible handle that looks great for years. Titanium is has a soft surface that is easily scratched. The best finish for this stuff would probable be to powder coat it.
Titanium, great for high performance aircraft, in my opinion, not great for knife handles.
