- Apr 30, 2002
#2 True North Knives 10th Anniversay of only 10 made and only embellished handle (except the two Mystery steel versions costing 2K)
I called CRK and they do not plan to make fancy handle UMMY's so get one of only 10 right now...instant gratification. New, unused, unmolested...just like I got it from Neil. I have a user model, so this new one needs a home.
Last .25 inch of top side is sharp unlike later models. Also the hollow grind is higher if you look at current tanto's. See how that flat area that forms a triangle is about 1 inch away from the tip. My current model and others I've seen in pictures are closer to the tip.
Specifications
Blade Length: 3.675"
Overall Length: 8.5"
Closed Length: 4.77"
Blade Steel: CPM S30V Stone Wash Finish
Blade thickness: 0.140" (3.56mm)
Fittings: 303 Stainless
Handle Material: 6AL 4V Titanium
Sheath Description: Pocket Clip
Weight: 5 ounces / 140 grams
TRADED
Specifications
TRADED
