TENTEX
- Sep 2, 2017
Yes Sir. Loosen and move up the cage on the bottle. Then find the seam on the glass. Once you do that you are good to go. Cheers Friends!Bravo!
TENTEXtbook technique on the opening!
You may have discovered the definitive use for the inertia generated by the TNT-- the follow-thru, so graceful, the decaptitation, so clean!
Cheers!![]()
I think that a real "working" champagne sabre/saber requires a specific right-hand/left-hand grind and technique to clear the ridge on the neck. It can be done.
I've done this many times and the blade was never meant to clear the ridge, but to crack it. It doesn't mess with the cork at all... It's meant to break the glass cleanly at the ridge.I think that a real "working" champagne sabre/saber requires a specific right-hand/left-hand grind and technique to clear the ridge on the neck. It can be done.
Agreed!TENTEX made as clean a job as I've ever seen with this task...note how he even recoils the blade back a bit <after decaptation>.
Top shelf form even considering there was no one in the path of the blade...this man knows how to sabre.
Greater follow-through-- although more showy & dramatic-- could result in a more gory sort of decapitation!
Samurai Sommelier, anyone?
I'm thankful for your backyard.
