- Feb 1, 2000
I'm making a neck knife with cocobolo scales that will be epoxied on. I'd like to blue the blade and the edge of the tang that will show all around the handle. Should I blue the knife first and then install the scales and pins (this would mean shaping and finishing the scales to their final fit and finish before glue up) or will it be o.k. to blue everything after epoxying the scales on and finishing them (this is how I usually do scales-glue on the slabs and shape and finish after curing)?
If I do the blueing after installing the scales would the cold
bluing solution erode the epoxy or penetrate the cocobolo wood? if the epoxy is impervious to the solution and the cocobolo is impervious to the solution and water then it really doesn't matter.
Thanks for the help!
Guy Thomas
Guy Thomas
