Tomcat 3.0 clip?
was just wondering are you still able to make a clip for my tomcat 3 just like the one in the picture below.
Thanks!
-Josh
attachment.php
Yes I have one stone washed one ready if you want it.
$40 is fine on it. I normally require the folder on these but the last one ordered I made two and kept the one back for another customer that asked for it. I contacted him about it months ago and never heard back so normally it is a bit more than this one on this folder since screws have to be replaced and it is tricky to get one to work with that tacky handle material. I must warn you this folder sticks to the pocket and sliding on and off is not the easiest with that handle due to how it grabs and holds the pocket. Therefore the stem is short on most of the newer ones I do and do not look quite like that one shown. I've found the less stem you can give on this clip the better it works as you don't really want a long travel to clip it with this one but a simple short stem pop on pop off holds it with this grip. The one I have works well, I'd use it myself if I owned the folder so again, you are welcome to it. Also, it is the last one so anyone reading this wanting a clip for a Tomcat will not have the same luxury since I will need the folder to cut the screws and line up the clip correctly on any after this one. I tried doing one for this model once without having the folder and the gent accepted it but it required some work on his part to make it sit as he wanted so I like having them to properly set the clip where it belongs. On this one though if you want it I already did all that with another folder earlier. Anyway thanks
STR
No sweat. Payment rec. and it went out this am. Thanks
STR
