- Oct 8, 2013
On a diamond hone is going from a 325 grit to 1200 to big of a jump?
Thank You.A 4X jump is fine, regardless of the type of stone.
Shapton purposely sells a set of Glass Stones that is 500-2K-16KI wouldn’t say 4x is fine as much as I’d say it’s ok if that is what you have.
2x is more of a standard progression.
Big jumps in grit progression are only important if you're trying to polish the bevels - it'll make it tougher to remove all the coarse-grit scratches before polishing. If you're polishing, then keep the grit jumps as narrow as you can.
Otherwise, jumping from a coarse (325) to EF (1200) can produce an extremely aggressive slicing edge that you might like a LOT. I tend to favor edges like that anymore, for the edges I use everyday. The 1200 will narrow the apex width atop the coarser, toothy biting edge left by the 325. That's a good thing, as I view it.
I've liked using a medium or fine ceramic to set a barely-there microbevel, after setting the edge with either a Coarse (325) DMT or even an XC (220) DMT. Either of the ceramics will be an even more extreme jump, as compared to following with an EF (1200) DMT. Take the refinement as far as you can with the coarse stage, thinning and deburring as much as you can. Then, just 2 or 3 very light passes per side with the finer hone will narrow the apex further and also clean up any remaining burr remnants. That makes for a great slicing edge.
No,not looking for high polish.Thank You.A large jump is no big deal as long as you are not working with much surface area. For a microbevel no problem at all. For a very wide, flat bevel it may be a little different. Especially as noted if you're really trying to get a consistently high polish across the entire surface.
