Sounds like the 'tip not as pointy as it used to be' may just be due to some rounding off of the tip during the reprofiling. Either the reprofile didn't quite extend fully through the tip, or it just got rounded off or blunted a bit. Could also be a burr that's upturned at the tip, which is created during the reprofile of the cutting edge (this happens a LOT more often than many may be aware). That barely-perceptible, upturned burr can prevent the tip from penetrating a piece of paper easily, if at all. Oftentimes, an easy fix is to just turn the blade over and lightly grind the spine down (tip-trailing passes) until it fully and cleanly intersects the newly-thinned cutting edge. Use a magnifier to check how 'close' it is to intersection, as you work the spine near the tip.
I think most of the 'fix' for it not cutting well now will be in making a more cleanly-apexed microbevel. It's not currently cutting well because the apex of the microbevel is likely incomplete, rounded off, too wide (in angle), or just burred too much. A cleaner apex will ensure it's still sharp and cuts well. Microbevelling is kind of tricky to do cleanly, if one takes too many passes at it (freehand); that'll increase the chance of an off-angle pass or two rounding off or widening the angle of the microbevel.
