donnord
- Dec 22, 2007
And learned a thing or 2. At first I took the knife apart and cleaned the bearings washers and friction surfaces with alcohol lubed them with CRK fluorinated grease. Well the knife did not like that I think. It was slow and did not flick well. The blade was also off-center, not the greases fault but mine. Thats the second thing I learned, final assembly of this knife seems to go better if the knife is locked open. That way you can adjust the centering on the lock side first by tightening the pivot screw on that lock side. So I took it back apart and cleaned the grease off and used KPL instead. The action is much better now. I had take my sebenzas apart and clean and lube them when I first got them. I think they sit around for a while and the factory lube dries up.
