- Oct 20, 2008
I have a LG 50# hammer, with the old style mule ear ram. I got the hammer recently, it came with a plow-sharpening style top die in the ram. I really have no use for that, and just got a used top die with a mild drawing radius. I started trying to remove the die that's in it now- no luck so far.
The tapered key isn't upset at the small end, so seemingly no problem there. I've been soaking it with PB blaster, and using a phenolic block and hammer to try to drive the key back out without mushrooming the end. It has not budged at all. There is a fairly thin shim on the other side, which appears to be mild steel.
I figure I'll just keep going with the above, more soaking and tapping. UNLESS- someone here has got a good tip or two about what to do in this situation. Can I tap either way on the side of the die itself, to try to unseat it? Or would that be counterproductive? Can I heat the ram with a torch to loosen the die?
Any advice would be greatly appreciated.
Salem
Salem
