I got the Tanto Point BEST and Border Crossing from Mike to evaluate and show around to potential law enforcement and SAR clients. I asked him the story behind the design of the blades.
He said that both models were direct responses to needs by Spec Operators on shorter, covert missions. The big one, as pictured above by Greg, was designed to have the ultimate chopping power of a big 9-14" blade, but in a short package that rides more easily on LBE (load bearing equipment), so they can get through tight spots and contort their bodies as necessary without a big blade interfering. The handle was designed to index easily in the hnad when its cold, with gloves on, or even if you hand is injured. It also doubles as an emergency fighter (try whipping it around a bit as a fighter -- although a tad blade-heavy, you can still wield it VERY effectively).
They also wanted it thick for prying (it is used as a small but stout breaching tool, eliminating the need to carry Hooligan bars and other very heavy entry tools), and asked for 154cm, because they often have to move in and out of marine environments, or snowy conditions where they don't have the time or luxury of blade maintenance (sharpening sounds can carry pretty far!). Mike said he had to keep increasing the "hump" on the spine to add the right amount of weight for choppoing, while maintaining a good overall balance. When I held this blade, I buzzed back and forth through thoughts of cleaving meat in the kitchen, chopping down an oak tree, battling an enemy, opening the door of my house without the keys, and using it to flip flapjacks on the backwoods griddle. LOL!
The border crossing is an all-around utility/fighting knife. Kept thick for prying, it still cuts like a demon, and is a great carry combat blade. It functions in forward grip, and, when you put it in reverse, it indexes into your hand superbly, and the edge of your palm stays against the small raised ramp on the spine perfectly, keeping it from sliding onto the blade. It also has a skull crusher on the pommel, discreetly placed, but very effective. You can bash the hell out of it with a baton to split wood, etc., and can pry the crap out of all sorts of things, even though the blade is only 4.5" overall, with a 4.25" cutting edge. It also has a great profile for skinning anything from squirrels to a rhino. I personally consider it the fixed-bade cousin of my CQT Magnum.
The sheaths have a rotating metal clip, rahter than the kydex ones of old. I have found that, in the field, kydex sheath clips break too easily under the stresses put on them when crawling and climbing in rough terrain. This breaking gets worse in cold conditions. Many spec operators have reported back from the field that they would prefer the metal clips as well. You can rotate the sheath on the clip to any angle, and it stays very well. The clip is a b!itch to pull apart enough to slide it onto a belt, but that is a very big positive for me. It ain't coming off!
A substantial number of each model were made for the soldiers conducting ops in Afghanistan, sterile, without any logos or markings --(EDIT) I don't know how many, the 500 number was way off, my mistake. They have been sighted by many over there on the gear of our operators in both the elite units of the Army and Navy, and reports back from the field are that the owners are VERY pleased with the performance.
All of TOPS models are designed for mission specific purposes, with knives going back and forth between the untis and TOPS until they hit exactly what they want. Field R&D under harsh conditions, until it is a proven performer. Pretty cool.
In case you didn't know, Mike Fuller is a decorated Special Forces veteran, having served multiple tours in Vietnam. He has seen and done more than most, for several years in combat, and utilizes that knowledge to make sure his brothers in the field are properly equipped.
Best,
Brian.
