TOPS Rinaldi Armegeddon
I got this a few days ago and had a chance to play with a downed poplar tree yesterday. This is my first TOPS blade and it's definitely a solid hunk of 0.25" thick 1095 steel. It came with a kydex sheath. I measured it at 700 gm without the sheath. It seems to balance right around where the edge starts at the front of the choil. OAL is 16.5." The blade is 10.75" from tip to micarta and has 9.75" of cutting edge.
The black (linen?) micarta handles feel pretty good but would be better with a little more radius around the edges. Fit and finish on the blade are very good, but the sheath's retention was not very strong. I heated the opening and tightened it in until the grab was satisfactory. The finger grooves and choil actually feel comfortable with my size medium hands. The rear hook on the handle proved to be very harsh and uncomfortable when I moved all 4 fingers to the rear grip section to get more leverage for chopping. It would be much better if it was rounded off and would still give good grip retention.
The edge sliced paper nicely out of the box. The poplar tree I cut on was ~3" thick in the chopped areas and still green and wet inside. I cut a 7' section off the end and then limbed it. The 0.75-1.0" branches were easily cut with one swing. I didn't count the number of swings to chop all the way through, but it was a relatively quick and easy process. At the end, the edge was still very sharp and I shaved a bunch of bark strips off. Interestingly, the bark has a very strong orange-citrus smell to it.
After all the word work, the egde still cut paper with almost the same effort as it initially took. There was a barely detectable chip in the blade on the recurve front area. It sharpened out without much effort and now has an even better paper-slicing edge. The black blade coating was scuffed some, but mostly just gunked up with sap and juice from the tree. There is no actual wear on the coating yet. I'm pretty impressed overall and will try to remember to post some updates after more use.
Well, it seems like I didn't format my pics all the same somehow :confused: .....oh well
Yeah, I've been impressed with the simplicity and variety from TOPS. I like their knives.
Do the handles have any sort of palm swell contours or are they just slabs rounded at the edges?
They have slight swells around the screws. You can sort of see it in the second picture. The contour is pretty subtle though. I'll try to take another pic directly above the handle and put it up in the next day or so.
Thanks for the review T2! The TOPS version doesnt reflect the ergonomic work I put into the customs by sculpting and shaping the handles, but it IS great knife in its own right. The thing is tough as nails, and wont ever ask for a break. My production of custom Armageddons is very small, and this a very good alternative for those looking for a blade of this type.:cool:
Take Care
Trace Rinaldi
www.THRblades.com
Tnkas for the comments Trace - I was hoping that the TOPS version had similar levels of sculpting, but I can see for the price, fairly flat slabs were order of the day.
www.THRblades.com
As the proud owner of a CPM 3V model, all I can say is I can't wait until the XL model joins it! :D
Owning the original and having held the TOPS version, I can say they aren't the same but, the TOPS model is a good cost effective solution for most people who want one without the long wait and added expense.
Hey Sid! See You in Vegas brother!
Take Care
Trace
