Bungwrench
Banned
- Dec 21, 2006
I just bought a TOPS Wolf Pup because I thought it was a neat little fixed blade. It is and I really like it. The thing came as dull as a butter knife. I actually tried to cut myself with it and I cannot slice into my hand with a good amount of pressure.
I have a Lansky system with the Coarse/Medium/Fine stones. The Coarse stone didn't do much after about 30 minutes at 20 degrees. It seems that the factory edge is 30 degrees per side. Seems a bit steep to me so I was going to try 20 or 25 degrees per side.
I have some questions:
1. To put a new bevel on this knife, should I buy the Lansky Extra Coarse Stone? Will that be fine? It's only about $6. Or should I buy a Diamond DMT whetstone in Coarse or Xtra Coarse or what? I have seen these for about $30.
2. The blade on the Wolf Pup is thick as heck. I have never had a small fixed blade with this thick of a blade. What edge angles would work best on something like this? The factory 30 degrees per side seem way obtuse.
Thank you.
Thank you.
