Tormec T7 sharpener
donkey12
Anyone familiar with this brand or use this brand. Stopped by my parents house and my dad had the T7. His uses are many but mainly for wood working tools. I used it today on a buck 119. It has a learning curve I guess but overall I was pretty happy. I like it being water cooled for the blade. I guess I'm asking if anyone is happy with this unit. His set up with various attachments is well over 1k, in my world that's alot!
If you search the Maintenance forum thread titles for Tormec, you should find several threads on it. Some might be kind of old.
Check Amazon search the brand Wen. That's what I have and it's been great. Same basic principle at a fraction of the cost and a 10" wheel 👍
I use a Tormek T8 professionally for everything from repairs to changing edge angles, etc. After using it for well over a year now I can say that there is a definite learning curve if you expect to get exceptional or even just good results.
Yes I'd agree. I spent 30 minutes sharpening my buck 119. It made a nice consistent angle or reprofile. But as far as sharp...it could be better. I'm sure that's me though using a new machine.
It probably just needed to be deburred if you've reached a consistent burr along the edge, the tendency is for heavy burr formation in general unless you take steps to minimize and/or remove the majority of the burr. I deburr right on the SG-250 stone by having an assistant turn the drive wheel very slowly by hand while I take a couple alternating passes on each side at roughly 2-3x the edge bevel angle. Then I use the same slow speed grinding to make an apex bevel at 15-20 DPS depending on the steel and edge angle as it needs to be higher than the edge angle to work the apex directly. This gives a very slicey edge that can often push cut newsprint right off that 220 grit wheel, put another way... it gives a very high combination of performance from push cutting to slicing and ideal edge retention in both cases.
