- Jun 10, 2007
Hi guys. I have been toying with the idea of sharpening using only the tormek stropping wheel. I have a home made frontal vertical base and I use the knife sharpening angle calculator.
I could buy a few wheels for different grit sizes, but would rather have one wheel with multiple strips of leather. I plan on using a low profile j-hook fastener. This is like modern day velcro. Classic velcro is called hook and loop. Of course the loop is the fuzzy side and the hook is the scratchy side
Modern jhook does not have the soft fuzzy side, just the rigid hook which sticks well to itself. Low profile is just that, it is very thin and thus is as firm as the surface it is glued to. I would use some highly tacky urethane contact cement that is probably banned in most states to glue the jhook strip to a new stropping wheel and the same glued to strips of leather to make interchangeable strops of varying coarseness.
I have a few knives with high end steel, so I will be using diamond. My question is how to prepare and load brand new leather strops with diamonds effectively and economically. The strips will be 1" wide and 18" long. Im considering working with diamond dust rather than sprays or pastes. Making paste seems easy enough.
Keep in mind that I will be starting with a relatively large particle size for effective steel removal, probably a 600 grit followed by maybe a 1200 or 1600 grit
My goal is to simplify the process, cutting down the number of steps and adjustments. My secondary goal is to produce a convex edge without some elaborate technique.
