- May 19, 2002
I thought I would share with you, the work I have done to make a tornado shelter. Next to my house, there is an old cistern. It is still in very good shape. It is circular, 9' across, and is 11' deep. When I started, it was full of water to the top, which I had to pump out. It is made of 2 courses of brick and glazed with a mortar cement slurry. The top arches up to form a dome at the top. I put about 30" of pea gravel in the bottom and put in a sump pump. I then poured a concrete floor about 8" thick. I pulled the original top off which was about a 6' square and formed up a for a concrete top. The new top is about a 6' square also but has an opening in it and has steel poured into it to build the hinges for the door onto. The concrete for the new top is 23" thick. I built the door out of rough sawn, oak, full, 2"x6" boards and laminated that with a 1/4" thick steel plate. I welded hooks for a chain inside the opening for the door and have 2 chains fastened to the door to fasten shut. I have a counter weight on a cable to assist opening the door as it is pretty heavy. My wife can open it. I built a ladder type stair to get into it. For air circulation I poured 2- 4" pvc pipes into the concrete, and ran one almost to the bottom, and the other one is short, just inside the top. There is natural air circulation with this setup. I have a handcrank blower off a forge to put on one of the pipes sometime to crank in some fresh air if we have a full house down there. For power, I ran a heavy cord in from our crawl space. We have one light down there plus the sump pump. We take our battery powered weather radio, a few flashlights, and shut ourselves in. The sump pump may run once a week, so flooding is not a problem. I put a whistle down there in case we get trapped in by a tree or other debris, like the house, I can blow into the short air pipe for help. I built 3 benches about 5' long to sit on. I scrounged up a few old hardhats, to wear just in case. Most storm related injuries are to the head. A few people in town and other parts of the county are aware of this shelter, to check on us if the SHTF out here. Some people have suggested we keep MREs and all types of stuff in there, but it is not a long term stay, just an hour or two at the most as the weather service is so good at following these storms and posting warnings. We had 10 people in there once during construction, and it could hold more. Let me know what you think on this setup
