No, this is not a torque wrench. The torque wrench is the tool that attaches to it - like a ratchet - which measure foot/pounds of pressure. It attaches to this "jig".
I think the absence of posts to this topic has more to do with the placement of the post! It would probably get a LOT more response in the "Maker's Forums" .
Fully hardened blades bend - they just break sooner than those knives differentially tempered or selectively hardened.
For instance,"selectively hardened" will mean only the edge was hardened.
"Differentially tempered" will mean that the temper was drawn "differently" at a much higher temperature on the spine than was the cutting edge to remove more hardness/brittleness to prevent cracking when bent! Get it?
The differentially tempered blade will have been fully hardened where the selectively hardened blade only had a hard edge to begin with.
Some makers will tell you that they would prefer to have tempered martinsite then unhardened austenite!
The tempered martensite has the "potential" of having a higher torque rating at the same degree of bending as does the un-hardened austenite. If you harden some 5160 or 1084 and then draw the temper back at about 500 degrees, you make a really nice spring. If these were your choices for a knife blade, and IF! you did your homework and heat treating correctly, you might get some considerable bend in your blade and still have it return to full straight. The unhardened "selectively hardened" blade may take a "set" at the same degree of bend.
Maybe.
Then there are grind variables such as flat, hollow, and convex, to name just a few.
On and on.
As a maker, I could spend an entire week testing all the variables on my knives, and not get any knife making done!
I am not at that point where I can afford the luxury of testing everything I do in all of its available ramifications.
My knives perform well, and my customers keep buying them repeatedly!
I must be doing something right.
I do some simple testing on each knife to ensure that my "recipe" hasn't changed from one knife to the next.
I'm fairly confident that my knives will perform any duty they are subjected to in the normal realm of cutlery.
I do not have one of these jigs - but may someday!
www.andersenforge.com
http://www.kbaknives.com/knifeconstruction.html
