^^^^ Exactly.
While I'm no construction worker, I'm in the "avid enthusiast" category of DYI home improvement guy, and I look for Torx screws every chance I get because they don't cam out anywhere near as easily.
I wonder when the OP says they are "easy to strip" if he is talking about stripping threads due to over torque, or if he is referring to cam out. Either way, if you're stripping threads, just don't crank down quite so hard because, as mentioned about, these suckers are really good at NOT caming out the way Philips do.
If you're just mis-stating that they cam out, you're likely using the wrong size star bit. If you use the correct size, it should not cam. If you go a little too small it will, and you'll round out the corners of your star bit, and that's bad.. m'kay?
