- Jul 1, 2002
Would it be wise to use the Apex for a simple touch-up using say, the 3000 grit polishing tapes or the 600 grit stone if the tape won't bring the edge back? The reason I ask this is because I sharpened my knives using the 21 degree setting and since the Sharpmaker only has a 15 and 20 degree setting, I'm out of luck there.
Also, I just thought of something that I might be doing wrong... when setting the angle, are the colored dots supposed to be above the pivot, covered by the pivot so that only a sliver of color is showing, or should the little notch in the dots be aligned with the top of the pivot?
Any help will be greatly appreciated. Thanks!
