touching up a 25 on a sharpmaker?
lathrop
My 25 needs a touch up. I use a sharpmaker on my 21s, the 25 has a slightly different edge. Is there a different approach for the 25?
I use the same technique as I do for the 21. Just make sure to keep your angles as consistent as possible.
I use the rod horizontally in the side of the sharp maker...feel like I have much better control. I press pretty hard with the white one, check for burrs, then use it soft a few passes on each side. Clean the rods frequently with soap and water to get the particles off. Then strop for a few minutes. My 21 is somewhere between shaving sharp and hair popping sharp.
