- Dec 20, 2005
I'll be making a tactical knife (3/16" thick stock) and was wondering which one of these steels is tougher? Or is the difference barely noticeable?
Thanks!
Thanks!
According to Crucible, CPM154 is superior to D2 by a wide margin in the categories of wear resistance, toughness and grindability. No contest.
I really can't see why D2 is still in use. It's about equal to 440C in the above categories - and it isn't stainless - one might argue not even almost stainless. (Is this because all the Chromium is tied up in carbides?)
My opinion is based on a small amount of use of both and also on the data sheet at the link below. I'm interested in hearing reasoned dissenting opinions.
www.rangeroriginal.com/CPM154.pdf
Rob!
Rob!
I'm a little skeptical in terms of the accuracy of the chart... it shows that 440C has the same wear resistance as D2 -I know that for a fact D2 will outcut 440C if both steels are heat treated to their optimum hardness. D2 will also outcut 154CM and ATS-34.
Since Crucible makes 154CM and CPM 154, could there be some spin-doctoring going on?
Flatgrinder
I'm sorry. I thought you were asking about CPM154 compared to regular D2. If you were asking about CPMD2, I can't answer. It should be tougher than regular D2, but Crucible has not even done a preliminary datasheet, so any information at this time would be anecdotal.
Rob!
