Important Info! Toxic vs Harmful
Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
I don't want to derail another existing thread, so I decided to post a new one. Post your thoughts, advice, and questions here.
Shop safety and good health care should be that you wear a respirator in any dust producing process, and that you vacuum up any dust residue that collects in the shop. If you don't breathe it it can't hurt you! It's that simple.
Comments like the below ones are common in the threads in Shop Talk:
"XYZ is highly toxic"
"G-10 is toxic"
"Grinding MOP will kill you because the dust is toxic"
"The fumes from galvanized pipe are toxic".
, etc.
While these things may cause various health problems from mild to deadly, they are not toxic.
Toxic means poisonous. If it damages living tissue because it has a chemical or poisonus effect on them, it is toxic. If it damages them because of a physical effect, it is harmful.
An example is G-10, which is glass fibers in an epoxy base. The glass gets sheared into minute pieces when the material is ground or sanded. There is also epoxy dust. The cured epoxy dust is virtually inert. It isn't good to breathe because it is dust, not poisonous. The glass fibers are the real danger. They can permanently damage your lungs, and may even cause cancer (due to irritation) when the particles get stuck in the linings of the lungs and bronchia. The damage is because they cause harm. not because they cause any chemical damage. This is why G-10 is harmful, not toxic. It is often compared to asbestos, but a look under a microscope will show a vast difference. The asbestos is friable has fuzz and barbs all over it. The glass is a mono-fiber that shears into smaller pieces, but they are still mono-fibers. Both are bad to breath into your lungs, but the results are very different.
Breathing any particulate dust is bad. If the dust isn't soluble in water or absorbable by your lung tissue, it will collect in the lungs. This reduces your ability to absorb oxygen. COPD, emphysema, , and some other lung diseases are the eventual result of repeated exposure. This is because the dust is harmful, not toxic.
Some common false impressions ... even by doctors ... are:
1) MOP is fatal/toxic to breathe because it has cyanide in it.
2) Super glue vapors or skin contact is toxic because they contain cyanide.
3) The smoke or vapors from heating galvanized pipe are toxic/fatal to breathe.
4) Poinsettia leaves are deadly poisonous.
Lets look at them one at a time:
1) Mother of pear is a piece of a shell. While it may smell funky when ground or sawn, it is just calcium carbonate. There is no cyanide or toxin. Breathing too much of the dust can make you feel ill and nauseous because you have absorbed too much and changed your blood Ph, ... as well as breathed a lot of dust which makes you oxygen deprived. Both these factors can make you cyanotic - blue lips and fingernails - which is a symptom of low blood oxygen ... not a diagnosis of cyanide poisoning ( which also turns you blue. The term cyanotic and cyanosis refers to the blue color ( cyan) not the toxin cyanide.
2) Super glue is a cyano-acrylic resin. It does not have cyanide in it, but is a carbon and a nitrogen atom bonded with a negative 1 valance. The catalyst is water molecules. When catalyzed, cyanoacrylic turns into a polymer acrylic chain.
The glue isn't good to get on you because it sticks to skin very well. The acrylics are not particularly harmful in the normal sense. The smell of CA glue is from the carrier/solvent. It isn't good to breathe because it is a powerful irritant, but not highly toxic.
3) Galvanized pipe/sheet, etc. is steel that has been coated with zinc to retard corrosion and rust. Zinc is very active chemically .... iron not as much. Zinc bonds tightly to the iron in the steel and steals all the oxygen that comes near it. The zinc oxide acts as a protective coating preventing any oxygen from reaching the iron and causing rust. This layer of zinc oxide is very thin, and usually invisible beyond a dull gray look. under it is lots more free zinc ready for any oxygen that comes along due to wear or aging of the outer film.When heated high enough, the free zing vaporizes and rapidly combines with the oxygen in the air. This causes the hot air and vapors to precipitate powdered zinc oxide. It is basically snowing zinc oxide. Zinc oxide is very stable and virtually in-absorbable. If you breathe it, it will not cause any harm besides what breathing a fine powder does ( as in the MOP dust). It will make you feel dizzy, weak, and nauseous ... not because it is toxic, but because it is limiting how much oxygen you are absorbing. Drinking a glass of milk will help settle your stomach ( it washes and carries any of the oral and esophageal dust down to your stomach where the digestive acids do away with them), going out into fresh air, and getting a good nights rest will cure the problem. This is called Metal Fume Fever. It is a problem of welders and people making fumes from melting metals. It is not fatal, but unpleasant. Avoiding breathing the dust/powder in the first place is how to avid getting it. A respirator will eliminate the risk.
The death a while back of Jim "Paw-Paw" Wilson is constantly used to validity the story that these fumes are toxic.
Jim was running a good size forge in a tightly closed shop, burning the galvanizing off some pipe ( and/or the plating off some brass items) with no ventilation or respirator while having a bad case of the flu. His lungs started weeping because of the exposure to the smoke and irritants as well as the low oxygen level in the shop - and he basically drown in his own fluids in less than 24 hours. The cause of his death was very bad judgement ( bordering on stupidity), not toxic fumes from zinc.
Zinc poisoning is a different thing. You can't get it from breathing or absorbing zinc oxide. It isn't common in humans, but affects some birds and small animals. It comes from ingesting certain zinc chemicals .... but not zinc oxide.
4) The poinsettia story is here to point out how a wives tale can become so ubiquitous that everyone knows it .... even when it is totally false. (When I was a kid, another one of these well accepted stories was about Spanish Fly, but we will leave that for google searching). If you walk into an ER tomorrow and say that your child has eaten a poinsettia leaf, they likely will go into code pink mode. As soon as someone calls the poison hotline or looks up the protocol for treatment/antidote, they will get the surprise of their career - it isn't poisonous! Poinsettia leaves are pretty much non-toxic. You could make a salad from them with no risk of dying, but you might get a rip-roaring case of diarrhea.
Other common stories are that lots of people die from Black Widow bites and rattlesnake bites. These stories are called FOAF stories ( friend of a friend) due to the frequent claims like "I knew a kid/man/person whose brother's son died form it..." Black widow bite deaths are so rare that some years have not even one in the entire US populating. Rattlesnakes cause about 3-5 deaths per year in the US. Horses kill five times as many more people than rattlesnakes, and deer kill hundreds of people a year
One real danger that few understand is beryllium. It is toxic and can kill you or make you very sick. Do not melt unknown copper alloys ... and never use beryllium alloys for any knife work. The dust is the worst, but even skin contact with the bare metal when grinding it can be very bad.
What's your take on ceramic fiber insulation like kaowool?
Kaowool, superglue, epoxy, sanding belts, almost anything we use for knife making comes with a MSDS sheet that defines any and all potential harzards a material may have. It will also list recommended ways to protect yourself from these hazards. http://insulationpr.com/cms/wp-content/uploads/2012/09/Kaowool-Blanket-MSDS.pdf which basically says keep it out of your eyes, nose, and mouth. It also says long term exposure to hundreds of times the normal 'occupational exposure' may cause cancer.
How does it compare with asbestos? When I bought it, I was told that it was essentially "man-made" asbestos.
great informational post, thank you!
that is how it behaves when exposed to heat and flame. health wise it appears to be quite benign. we are typically using such small amounts that basic common sense, safety glass, and a dust mask should be all the protection you need.
I suggest one correction to CA glues. The fumes can/are harmful which is why they say to use in well ventilated areas. Some people are more susceptible to the fumes than others [just like anything else] but breathing problems are known to have been caused from the fumes. Additionally, once you have problems form CA fumes they are compounded each time the fumes are breathed. Many hobbiers have had problems with CA fumes because they did not have well vented areas the glue was used. I quite using CA years ago due to a very mild reaction then reading about it. Please be careful with CA adhesives, they can be harmful.
As a general rule, toxin is the term that covered poison and venom. Simply put, a toxin is bad for you no matter how it gets into you. Skin, blood, food, mucus membranes, however.
On the topic of cyanide, while it is a deadly and fast acting toxin "not poison, it can kill you if injected or inhaled" it's not as deadly as many people think. Cyanide is an incredibly simple compound, CN. More complex toxins like alkaloids "most plan toxins" have relatively long term effects even if they aren't fatal. But cyanide is a relatively common natural compound, your body makes it as a byproduct and many plants contain it. It is also quite rapidly degraded in your body, and 10-20 minutes after it enters your body it is basically all gone. Not the boogy man most people think it is.
As for zinc fumes, I once explained it as the equevilent of hydrochloric acid. Yes, it's not GREAT for You, but spilling even rather concentrated HCl on yourself isn't really a big deal as long as you wash it off with a little water.
In all honestly, the thing most likely to kill a knife maker is carbon monoxide buildup from the forge. ALWAYS work in an open, well ventilated area and take breaks of no less than 5 minutes. Do you feel a sense of clarity on those breaks? Do you suddenly remember things? A settling feeling in your chest? Get out, breath, and vent out the shop. Carbon monoxide is a real killer.
The best thing to remember is " use in well ventilated area " !! Medical research continues to find things best avoided. Can things get into your system fast ? Yes, try toxic encephalopathy .Most doctors don't believe that one !
Ground shell, mother of pearl and silica from grinding stone...may as well be inhaling a million microscopic slipjoints into your lungs.
How about cold bluing or parkerizing on blades? Both finishes are technically toxic, but I still see them quite a bit on kitchen knives. Is it just that the amounts are so tiny that it doesn't really matter?
Another common wrong conclusion. The chemicals used in these processes may be toxic, but the finish produced on the blade is merely patinated steel. The blade is no more toxic that it was when sanded bright.
My understanding was that in both cases the patina that these leave is something other than the usual iron oxide (manganese phosphate in the case of Parkerizing and copper selenide in the case of cold bluing). I know iron oxide is totally safe, but those two compounds are toxic, from what I've read (?)
If you have concerns about safety, go to the MSDS. after bluing, you have a coating several molecules thick. if you removed all the bluing from a blade, you would not have enough pure manganese phosphate to exceed OHSA's chronic exposure limits. It is the process where possible hazards lie, strong acid or alkaline solutions that may be heated to boiling point. Polyurethane finish when dried is perfectly safe, it is the solvents that can cause fire or explosion or personal injury.
I agree that people may be incorrectly tossing around the term "toxic", however, it's good to note that many of the things mistakenly labeled toxic can still be quite harmful to our health. I feel it's important to emphasize safety to avoid damaging our long term health.
Although I'm a rank newbie, I'm sure glad that I only made one knife before I read the advice to use a good respirator when grinding (metal or wood or whatever). I'm still stunned by the number of online videos I see where people are grinding without any type of personal protective equipment. Any while it's not toxic, I won't be staring into a forge for long periods of time without proper eye protection.
Both toxic and harmful can seriously hurt (or kill) you. Both should be dealt with properly. That is why you need to understand which is which and how to avoid the dangers.
Just an add on comment, but many toxic things can be safely drank, but will kill you if they prick the skin, and many harmful things can be bathed in, but will kill you if you breathe them.
Same sort of fiction gets going over spalted wood. People will tell you how dangerous it is and the fungal spores will get in your lungs and cause blah blah blah blah blah. Do a bit of reading and you wear a respirator because of the dust particles...the fungal spores are not the issue unless you keep your house really wet and dark inside. And then the mould problem will be far more than the piece of spalted wood in your house.
