Folx,
as I await arrival of driving pulley for my Mark II HMGrinder (the thing
is too big for me to turn it on me mini-lathe), I am going about building
the bader-like grinder (VFD and everything !).
It is going rather smoothly. Tracking pulley design is where I could use
some help.
It is rather straightforward to design one where the tracking axis' tip
moves up'n'down - the axis mounts on the plate that is hinged to the
tensioner arm and then there's a bolt that pushes the hinge up, against
the belt's pressure that naturally resists that.
Now, is there a merit to changing that to design where tip moves left/right ?
And if yes, then how one would go about that ? The problem being that the
tracking screw now needs to push the hinged axis' mount both ways, as there
no belt tension anymore that would hold it ?
I originally went with L/R design (that's how my Mark I operates, more or less). Made a hinge and everything, to realize I can not come up with how
to have the adjustment screw drive it _both_ ways.
I can DT either the arm or the axis' mount. Problem: how do I make the OTHER end stationary - when it has to both rotate (being a screw) and
pivot ?
Am I overengineering here ? Ideas appreciated, pictures even more so !
some help.
pivot ?
