When I first tried the Osprey Kestrel 48 I actually went into an outfitter thinking I'd be picking up a Kelty Redwing 50. Didn't take but a second to screen out the Kelty from the packs I was considering. Never even put a load in it to try it on. For me the Kelty would probably make a good travel pack (airports, airplane carry on, and such), but that isn't what I was after. Bottom line is you have to load it and tote it before making a decision.I like panel loading packs myself, because rummaging around for things in top loading bags gets old after a while. Top loader/bag type packs are sturdier, less prone to open, and look nice, but I figure zipper technology is so much better (i.e. stronger), so I'm willing to bet panel loaders hold up well. It's great to be able to open your pack, either fully opened or partially, to pack and unpack your things. Compression straps probably add strength to keep panel loaders closed. The Kelty Redwing is a half panel loader (best of both worlds)...I've been eyeing this for a while and seems like a solid choice.
Notice the tumplines. Do you really want to use the crown of your head, neck, and spine as part of the load bearing? There are valid reasons we found four even large capacity packs a way to transfer much of the load off your shoulders and to your hips rather than to your head, neck, and spine. Tumplines were/are part of a life of drudgery and danger. Not much nostalgic about them.http://alderstream.wcha.org/packs.html
I don't own any of their packs, but I had a chance to check them out personally and they are top quality.
We're talking a daypack, so if you're worried about the lack of modern suspension systems you may be carrying too much.
An option for the old-style large packs would be to combine them with a Roycroft pack frame. This could be made as comfortable as most of the modern packs for heavy loads. As well, a large pack does not necessarily mean heavy - you may just want ease of packing (put your dry sack in, stuff the sleeping bag, and put the rest on top, and you have a slightly more bulky but 5 times faster system which is easier on your bag too) - and tumplines are actually for comfort rather than 'drudgery and danger' (but how progressive to think how everything contemporary is better). The tumpline will keep your head aligned and save some strain on your hips and back. They just have to be used properly and they can be a great tool. Even with the best modern systems they are helpful, especially going uphill.
And that is nothing against modern stuff. I have an Arc'teryx Altra which is pretty much the best suspension system you can get, although it's not an ultralite pack with its system, heavy material, and waterproofing; so my biases may still be clear. I like tough stuff that is versatile, and I can see the advantages of old systems as. One should remember that most old-timers were not travelling green-pilgrimage trails and posting their daily distance on Facebook, they were building camps, going to work, and hunting. This did not provide for clear, premade paths, and an ultralite pack would get torn to shreds from the brush. Canoeing and winter trekking also tend to be better with traditional systems, mainly because the shapes pack better and the materials do not degrade so readily from the elements.
I'm often a traditionalist, but not so when it comes to packs. There are so many better options than top loaders made of heavy materials and neither designed for fit, ergonomics, nor stowage of gear --- even in smaller packs. Traditional packs look cool but really just aren't as well designed/convenient or comfortable.
Let's also remember those old timers were living lives filled with times of drudgery. And packing loads was one of those times. If they had an option between the pack they were carrying or a modern pack (most of which don't fill the bill for lightweight backpacking and certainly not ultralight backpacking), which do you think they'd choose and why?
