Traditional Nepali Sharpening Methods
Anyone have any documentation on how the people of Nepal traditionally sharpened their khukuris? Yes, I know they used a smooth rock or something similar in combination with the chakma - but I'm more intrigued by the detailed techniques involved.
How sharp could they get them using these methods vs. power tools or modern hones?
Were they made a bit softer for use with as-found sharpening implements?
thanks much- Mike
Really the level of sharpness that ANYONE can achieve is based on skill and level of polish. A power tool will only get a knife so sharp and even that requires the skill to do it. It just makes getting an edge much faster:)
As for how they do it in Nepal, I don't really know. I would assume that the would steel the blade with a chakma like tool often while they cut and hit it with a file or two when they needed too. If used with care and sharpened expertly, then it should take a good lifetime to wear out the hardened edge of a khuk. On top of that, a good kami can re-heat treat the worn down and softer edge so that wearing a khuk out could easily take generations of hard daily use.
I'm also willing to bet that most Nepali people rely on skill over edge. With a good working toothy edge they could probably out work/chop those of us with even the sharpest of hair shiveringly sharp edges.
For information on an older forging/sharpening method in use at the BirGhorka factory, try this description of the "magic stone" on the main website. This would seem to show at least one method of Nepali sharpening (as was pointed out to me, when I raised a similar question).
Well I grew up in a small rural, village in Southern Leyte, Philippines and didn't move here until I was 9 or so. It was a mountainous, tropical area near the sea. A lot of people were farmers (including my grandfather), so I grew up around bolos, axes and other traditional tools. The farmers/villagers used simple, cheap (probably imported from china) double-sided stones (rough/fine [110/220 grit?]) to sharpen up their tools. No one ever justified putting a great edge on their tools since they were used for several hours a day and would most likely chip/roll from hitting rocks and such anyways. Socioeconomically, Nepal probably isn't much different - they're not exactly cut off from the world, and I would imagine that they import the same crummy sort of stones and people buy them as they're cheap, get the job done and are more effective that what you used to be able to get natively (at least for the price) :rolleyes:
While I was up in Canada for the winter visiting my father, he brought up a bolo from the basement that my late Tatay (grandfather) had put together for him... the blade wasn't made by my grandfather, but the handle and scabbard were. Simple hardwoods with nicely braided fishing line to hold stuff tightly together. The blade was quite chipped/rolled/dented up from hard use, so I sharpened it back up to a razor edge keeping the original bevel type (but with a polish up to 1200grit). The normal method of sharpening is actually quite interesting and I remember my Tatay teaching it to me: essentially, the bevel was a chisel grind (but convex due to freehanding). You'd sharpen the angled side with the "coarse" side until a bur was formed... then you'd simply get rid of this using the "fine" side of the stone on the flat side of the bolo. The rest of the bur was just knocked off with use, leaving a sharp yet toothy edge. I have to say that the method was quick, simple and did the trick (even with low grit stones)
fascinating, guys. Thanks. I'm in agreement that working edges don't need to be endlessly fussed over - an easily-maintained toothy bite works quite well for general work.
Good post, Killa:thumbup:
I enjoyed the information and appreciate the family history you shared:)
Mark
I got my first Khukuri today and sharpened it up the traditional way just like hundreds of years ago - mousepad & wet and dry sandpaper! Well it worked anyway, my 15" Ganga Ram can now shave leg hair - it doesn't shave well and I don't think I really need a razor edge on it, but it does shave and I think it is sharp enough to bite deep into wood. I managed to get the Karda sharper using pretty much the same method.
I used 400 grit then 1200 grit then stropped with green compound. Maybe not the traditional method buy it was cheap and effective.
