The were unanimous: "Raise the spine about 1/16 inch so the flat of the blade clears the stone. push the edge across the stone. Never pull the edge. If you pull the edge you get a burr. Burrs are bad."
They were all a "fan" of stropping first, and if that didn't restore your working edge, then and only then use the stone. That expends the life of the blade(s) knife by years.
Neither of my grandfathers were good at sharpening, and they should have been. One was a hunter/fisher to the point of having it tear up his family life, and the other was a barber. The hunter/fisher lived in Texas City and traded fresh fish for knife sharpening services at local fixit shop. Back in the mid 60s, I watched him and my father repair edges on occasion when a knife was damaged or in bad shape. They used an India stone to repair fixed hunting knives that were in trouble after a particularly hefty pelvic bone split, or some light chopping deformed the edge. They could get it back to cutting, but since they used the "swirling grind method" of swirling the blade in circles, no bigger than a nickel, on the stone it wasn't much of an edge. The "fixit" guy (who could also repair toasters, fans and lawnmowers) was responsible for a keen edge when going hunting.
My other grandfather was a barber. He couldn't repair a damaged edge, but if your knife was just dull and needed a touch up, he was your guy. He stropped his knife on the same horsehide strop he had on his chair, and back then the old carbon steel knives we had would easily shave when he got through with them. He was the only barber in his little town; if you came in regularly, he would touch up your knife as a freebie with a haircut.
I could get my knives sharp enough for a kid, but wanted more. Then I got a Buck 119 in '72, and it had instructions.
afishhunter
, they were almost identical to your instructions. Carefully place the knife, raise the spine, and the motion was to be from heel to tip of the blade, carefully making sure the angle and pressure were the same for every stroke. The big tip in the instruction sheet was to use a "cutting motion on the stone" as if you were going to cut off a layer the equivalent to a sheet of paper. Fixed me right up, Buck did. Lots of practice, some good stones and I was in business.
