Traditional style PVC khuk sheath
After I redid my PK, the old sheath didn't fit right. Modifying it was not so good since the light, soft, wood liner had broken in a couple of places.
I like the traditional style of sheath, It is very practical and comfortable to wear, especially with a modern nylon frog. However, the soft wooden clamshell liner could be improved.
Not only is it fragile, but you run the risk of inadvertently cutting the scabbard leather and maybe even cutting yourself. There was even a small cut in the leather when I got my PK.
All in all, it's a good system, it just needs a wee bit of an upgrade with some modern materials.
So, I decided to make a traditional style scabbard, but with a one piece liner made of a modern material, both for durability and safety.
I went down to Home Depot and for $2 got a 4ft piece of 1-1/2" PVC pipe. I heated a section of one end of it up over a charcoal barbecue grill, bent it and flattened it.
NOTE: You should bend it BEFORE you flatten it, as when you flatten it the plastic will acquire a new 'memory' and it will frustrating to bend it after that where it will stay bent.
After I got it shaped and formed, I made it tight so it would hold the blade firmly but still allow a one hand, quick withdrawal.
I then cut off the section that was to be the scabbard and trimmed the scabbard tip with a hacksaw.
Then I stuck the trimmed scabbard tip back in real close to the charcoal so only the tip would heat. With the tip soft, I pinched the ends closed and into shape with a pair of pliers.
After it cooled, I glued the end together and shut with PVC pipe glue, holding it firmly but gently shut for drying with a pair of vice grips. After it dried, I trimmed the end with a file and then buffed the entire scabbard liner with 60 grit sandpaper.
I then glued a leather slide-stop to the top to help keep the scabbard in the frog. The adhesive used was 3M automotive super weatherstrip adhesive.
I didn't have enough thin leather on hand, so I covered the scabbard with thick, waterproof, black cordura nylon backpack fabric.
The scabbard was sewn up the back in the traditional manner. I also sealed the seams and protected the threads in the way I do with my leather and wood scabbards with black Permatex automotive super weatherstrip adhesive.
I also reused the brass chape from the old scabbard. The chape had been previously modified to be rounded out and it was modified a bit to fit the new scabbard. A drainage hole was drilled though the chape and into the scabbard.
Here is the current rig as I have not yet made a new nylon frog for it yet. The brass rod is an EZ-Lap Model M diamond sharpener and the pouch holds a standard, bar style, magnesium firetool. The lacing is military paracord.
:cool:
but don't give the village sarki this idea.
I like mine to arrive with the traditional innards.
:D
ddean said:
:cool:
:D
Maybe I should ship some PVC pipe to BirGorkha, along with maybe some more JB Weld :)
I'm not sure what exactly that wood is they are using for the original scabbard liners but it feels almost like balsa.
