- Feb 23, 2019
I'm 13 years old and I trap Lynx and Foxes. I needed some knives to skin them and I saw some old table-saw blades. They are small but big enough for a skinning knife. I started planning a way to make myself a knife without a forge(because I don't have one).
Tools:
-torch(small hand held - available at hardware stores)
-grinder
-belt sander(that could resist to metal)
-metal clamps
-small pliers
-gloves and safety glasses
-metal saw
-a drill with a bit the same size of the nails
Materials:
-1 saw blade
-2 nails
-5 minutes epoxy
-any wood
I drew the knife I wanted on the blade and then cut it with the grinder. Step 2, making 2 holes for the pins of the handle. Step 3 is to quinch your knife. It won't work because I didn't forge it. When you forge a knife, you heat it over a cherry red color and it gets your metal softer so you need to quinch it to get it back hard but it gets harder then it was at the beginning. Saw blades are not hard enough to make a knife so we need to quinch your knife but how? Clamp your blade and hold the clamp. Take the torch to heat Your blade. When you get a cherry red, heat it for at least one more minute. After, let it slowly cool down. Now, you are reaty for the quinch! Heat your blade the same way and then quinch it in old oil in a can of soup that you can get after changing the oil in your car or truck. Step 4, the handle!
This is my favorite part. Trace the shape of your handle but a little bigger in case of mistakes. Now cut it with a metal saw. Make your holes in your handle aligned with the ones in the blade. Now it's 5 minutes epoxy time. Put epoxy on each side of the handle part of your blade. Put your wood at the wright spot and use nails as pins, clamp it and let it dry.
24 hours later, cut the edges of the nails off. now form your handle the shape you want with the belt sander. Step 5, you can now sharpen your knife and your'e done.
My first knife ended up like this:
Tools:
-grinder
-metal clamps
-small pliers
-metal saw
Materials:
-1 saw blade
-2 nails
-5 minutes epoxy
-any wood
