Traps
ducati
I always see pictures of dead fall traps and springing snare traps. Does anyone actually catch anything in them? Don't get me wrong, but I carry 4-6 snares in my pack. I know the snares work as I have snared, squirrel, rabbit, ground hog and coon. The time and energy it takes for the snares is minimal. They are light in weight also.
Yes... deadfalls and spring-up traps do work.
But for serious meat-getting with the least time and effort your current snares are as good as anything in my opinion.
Wire snares are strong, and they are very convenient to use in that they hold their shape. Because they are relatively stiff, they stay open in position without having to go to a lot of trouble to support them.
However, in my experience at least, once you've caught a critter in a wire snare, chances are the snare will be kinked which will make it harder to set next time.
I've trapped hundreds of animals in home-made snares, most of them made from synthetic cord. I like using nylon braid because it has a shock-absorbing stretch factor. I've had very few break-offs or chew-offs. And I generally always use a simple running noose with no form of lock. I figure that if the animal breaks the tether, then he has a chance of shedding the snare fairly soon. If the animal got a way with a locked snare around its neck, life could be uncomfortable.
Deadfalls and spring-ups are good traps to understand. If you don't have decent cordage for snares, then they are a good option. You don't need any cordage for certain deadfall traps. And when a critter is held in a spring-up, it cant get much traction on the ground... and it can be harder for it to turn and chew the cord. So I believe you can get away with using relatively weak cord for your spring-up snare. Also the spring mechanism helps to reduce sudden shock loads on the snare.
Where a snared animal is likely to be eaten by a scavenger before the trapper gets to it, then it could be a good idea to have a spring-up that lifts the trapped animal out of reach. I've never had to do this in my neighborhood.
Deadfalls are particularly good for rodents. I've caught lots of rats and mice using a figure-four trigger.
Best wishes from New Zealand.
I've have harvested game with dead fall traps repeatedly. they are not as fast or as reliable as wire snares, or commercial bought traps.. from a minimalist perspective. they are simple, effective can be made from nothing but a blade and the environment.. and work just about anywhere in the world. However as I mentioned there are drawbacks.. but several millenia of use by aboriginal peoples around the world is a testimony to there success..
SO yeah I;ve used them , I will continue to practice them, however when all is said and done a .22 wins it for me everytime.
I haven't ever tried to catch a critter in a home-made trap...but I like to have the knowledge JIC. I think any trap/snare is low-percentage...but I have confidence they would work, if a lil critter ever came by to investigate.
LOL I carry wire snares too...and 2 rat traps. I'm very much an alumni of the School of Back-Up Redundancy!
The thing I like about learning the basic principles of trap making is that they can then be sized up or down accordingly. Once you master say a deadfall trap you can make them small enough to take a mouse or large enough to take a bear~ just remember the weight needs to be 5 times more than the prey.
Same thing with snare type traps,that same trap that takes a rabbit can be made with a more heavy duty cordage and catch a deer.
The big advantage trapping has over hunting for food is that they carry on working when you don't.
I have used snares made of weed wacker cord and they dont kink, at least the brand I have used. I have caught animals in snares and traps and used to use pan traps growing up.
